M
marecean
I am new to the forum and thought I would post a problem with my 2001 Z06 that someone may be able to provide some sound advice.
The car is away for the season and I thought it was a good time to analyze the problems before I sent the car to the dealer for repairs.
Here are the symptoms:
TCS and ABS lights on the dash both on.
The HVAC control has no power to the dash.
Diagnostic codes as follows:
PCM: P1571 C H, P1689 C H
TCS: No Comms
BCM: B0432 C H - this relates to a broken wire for the rear defrost circuit.
SDM: U1040 C H
HVAC: No Comms
Prior to putting away for the winter, I thought I might have grounding problems, so I cleaned the two grounds in the engine bay and found the problems did not change. Have started the car over the winter, reset from the battery not connected has had no effect on the problems.
That is about it, hope someone can point me in the right direction.
TCS: No Comms
SDM: U1040 C H
HVAC: No Comms
