Bolisk
Since I bought by '70, the temp gague has never read correctly. It always read 140 when the car was fully warmed up. I have sense repladed every part of the cooling system except for the wireing harness and the temp gauge. Sill only reads 140 when fully warmed up. When the engine is cold, the needle is way below the 100 on the dial.
For x-mas, my wife bought be an IR temp gun, and I was able to confirm that the engine seems to be running arround 187-215 when fully warmed up.
Yesterday, on the way home, I drove over a plastic bag, and I immedately became concerned that it was sucked up agains the radiator because I didn't see the bag in my rear view mirror. Sure enough I saw the engine temp climb up over 155 on the gauge. . .then right on upto arround 180. An appearent increase of about 40 degrees. Using the numbers from the IR temp gun, that would put me arround 255 in the worse case scenario. YIKES!
I nursed the car home. . .and pulled it into the garage. I left the car running because I wanted to see what the acutal temp of the car was using the IR temp gun. I opened the hood. . .only to find that there was no plastic bag in the radiator. . .or anywhere that I could find. . .but the needle on the gague was still reading ~180. I immedaitly took the cars temp. . .and was supprised to find that the car was actually runing at 187!! The needle now appears to be reading correctly!!!
This morning, when I walked past the car, I noticed that the temp gague (after a full nite's cooling) now reads 100, the needle does not fall below the 100 on the dial anymore.
Is it possible that my gague fixed itself?!?!?! Anyone ever see anything like this?!?!? Where should the needle point with the car is fully cooled off (at 100, or below)?!?!?
Regards,
Bolisk
Regards,
Bolisk
