interior lights won't go on when doors are open
N
nicksc4
interior lights on my 1984
when i turn the head lite switch to the left my interior lights work, but they will not go on when i open the doors????? also the rear hatch switch on the drivers door and passenger door won't open the rear hatch, the fuse is fine ??? any suggestions,, thanks nick
vigman
Motor head!!!!
Valencia, CA,USA
Ok this ones a bit weird....
You need to answer the following.
It's a coupe correct?
When you open the rear hatch the REAR lights ( behind the seats ) are the only ones coming on..correct.
You turn on the dash switch and ALL the courtsey lights work..right?
When the doors are closed you can push the door light in and that works ...right?
And this happened all of a sudden..right?
Vig!
N
nicksc4
len,
thanks i'll check it out, the hatch from the center council works fine
vig,
i have to say yes to all of the above you hit it right on the head,
vigman
Motor head!!!!
Valencia, CA,USA
The delay module
It's dead ... will post more....
Do a search for interior lights....
we've been down this road before in the CAC
The truth is in here!
Vig!
vigman
Motor head!!!!
Valencia, CA,USA
