rickyric
New member
I'm having a problem that has cropped up here just in the last two weeks.
I'm hoping someone has seen this before.
The engine has been just quitting suddenly as if you were turning off the ignition. All power remains on and all accessories are still working. The car will turn over and start sometimes and then other times it won't start at all. In that case, if I wait 3 to 10 minutes or so it will start again.
The optispark and water pump are new, (less than a year old), I have replaced the coil and the fuel relay, checked the fuses, cleaned and checked the connections to the opti, coil, etc.
The only code preset in diagnostics is on mod. 4 / code 16. (Direct Ignition (DI) Fault I believe).
The car had one modification to it before I bought it which is a Cobra auto start / door lock remote module and key fobs. I think they replace the original PKE receiver with the Cobra. This unit has been nothing but trouble from day one. If works, then it doesn't. It randomly would unlock the doors, occasionally pop the hatch, set off the car alarm, etc. I disconnected the wiring harness to the unit thinking it might be causing the ignition problem but it had no effect.
One more important clue, when the engine gets up to it's normal operating temperature, the problem goes away and the car seems to run normally.
Any ideas here?
I need my Ruby Red baby back!
Any suggestions would be very much appreciated!
Cheers,
Ricky
Any ideas here?
Cheers,
Ricky
