My C6 is coming out of storage and will be fired up for the first time in 6 months. With my C4, I would always unhook the ignition coil so i could crank the engine until oil pressure would build before I actually started the engine. Is there any way to do a similar thing easily with a "modern" Vette? I'd imagine pulling the right fuse (or maybe two) would do it, but which ones can be pulled without upsetting the ECM? Any suggestions would be welcome!
