hzl6cm
I bought an old car last weekend that has ' 58 Corvette 283 block in it and wondered if this block has any value to the corvette enthusiets (above what any other non-Corvette 283 would be worth. Casting number is 3737739, date code is B298 and F528D is stamped on the front of the block. According to the Black Book this block was used in '58 and early 59 Corvettes. The heads are 3814480 E2863 heads which would be a non-Corvette 1962 283/327 head.
I had somebody tell me they though this block would be worth quite a bit to a Corvette enthusiest, I don't neccessarily believe him but thought I would check just to make sure since it doesn't matter what engine I run in the car.
I do own two Corvettes, a 1970 350hp 4-speed Convertible and an '86 Z51 Coupe.
By the way, the car with the Corvette engine is a 1967 MGB GT and it also has a Corvair transaxle in the rear. A NASA engineer built the car in the early '70s to compete against the Corvettes and Cobras - lots of power, very light weight and a 50/50 weight distribution.
Thanks.
Thanks.
