Help! Is this an L82???
charlesb
New member
San Antonio
1974 L82 Red
;help Finally, after many years of saving, I am a first time Corvette owner> I just got a 1974 "L82". The previous owner promises that it is really an L82. I am trying to verify that it is a true L82. I have looked up the VIN and it indicates L82. I am worried about the motor, as the car has been restored. The only numbers that I can find are on the front right block V0121CLR. I have looked all over the internet and cannot find out what this means. Can anyone help?? thanks a lot.
Charles
Charles
According to my book CLR was 1974 L82/4sp 350!!:thumb
The shortblock in your Vette was assembled in Flint, Michigan (V); on January, 21st (0121); and was originally designated as a 1973 -74 350 engine (vin code T, L82) with a manual 4-speed transmission (all this means "CLR").
Now, this code was typically used to identify the engine regular production order (RPO) number, but it basically it is also referred as the Short-block code.
What you should see in front (or meaning before) that code the last 8 (I believe) digits of the Vette's vin. Can you see this?
Also, CLR was also used for the 1978 (Vin code L, L48) for Vettes and Monte Carlos', so that is why the vin portion before the short block code is important in deciphering your Vette's originality.
p.s. You should be able to find in your local book store (or eBay) a "Chevrolet V-8 Small Block ID Guide" or something like that. There are also Corvette Parts Interchange" manuals available, but mine does not have a dedicated section to decipher every Chevy V8 code. It just tells you whether a particular code was also used on another car line (i.e. Z28 Camaro, Impala, and so on). I have a pocket-size one from MSA-1 that is perfect for car shows or take along with you at auctions or when looking a Vette for sale by a private individual.
L82
Thank you everyone. This is great information. I was a little worried about it. The car is being shipped right now, but as soon as I get it I will try to get the other numbers and a photo. Thank you again for all your help.
Charles
