Hi Jon, don't know if this will help, but sounds like there are two problems,separate from each other. 1.) turning( I gather switch back type l's & r's), 2.)Going in gear clunk. Hope I have it right? Problem #2: does it do it when going into drive? If Yes,then look for something external to the tranny, like the guys said trans mount,carrier stability,rear support stability,camber rod plate, spring mount. If the clunk is only in reverse engagement then sounds like internal problem( I can't offer anything, don't know much about AT's). Problem #2: Do you hear one loud clunk for each change in direction? Do you hear a series of clunks until you return to straight, and then the clunks start again when you turn the other way? I had a ' 72 so I am not sure the center sections are the same. If they are, the one clunk symptom could be weak pre-load springs and or a problem with the gears on the cross shafts( unlikely on the cross shaft & gears). The series of clunks when doing L's & R's indicate a posi clutch pack problem, which when it gets real bad it does it in a straight line. The clutchs could be burnt and or the pre-load cage with the springs could be bad( usually just the springs). Most of the time the posi fluid is N/G and it gets gummy and R&Ring it wont fix the problem you gotta flush out the carrier with CRC or tranny fluid then fresh refill and test it. Hope this adds something to the resolution. tomtom72
