jack points
  • Thread starter Thread starter Powdercoater
P
Powdercoater
This may sound stupid...but before I put the floor jack thru the floor pan I thought I would ask where the proper lift points are on an 84....I dont have a owners manu on the car yet....so I figuar asking is the safest way to go..Thanks
hi there powdercoater,
if you look on each side front and rear of the car down along the lower sill you will see two small arrows facing up and that is where you carefully jack her up from!
also you can jack the car up from under neath the front under the front lower centre cross memer!
and from the rear to one side under the alloy suspension part, not sure what that is called!
cheers
glen
sxyvet
australia
Thanks !! I also noticed all the other neat posts after I posted the question...
