Just burned up third Jacobs ignition
  • Thread starter Thread starter dsagers
D
dsagers
Just burned up the third Jacobs ignition system. Now I need to decide if I have it repaired again or just go for another system.
This is a HEI on a BBC engine running 4 psi of boost, usually never see high RPM.
The Jacobs system is going on 5 years old, and has been sent in twice before for repairs, there has to be something better out there, any suggestions?
There a LOT of msd systems in use. Sure, they crap out too ... but their failure rate is probably very small.
JACK:gap
MSD and Crane are the usual suspects. Mallory if your on a budget.
I have a Crane in my supercharged Z28 and MSD in my Vette. Both work just fine. the Crane BTM is a nicer setup than the MSD (it's all in the same box - no second box is required).
I have to ask if your coil is matched to the ignition box. A coil mis-match will eat the ignition...
Good luck,
Allen
I'm using the coil that Jacobs sold me when I bought the full system, assume it's the right one, but I'll check into that.
