LT4 Just got the dream car LT4 CE
1996 LT4 Topic
Dammit man
Lafayette LA
1996 LT4 CE
It has 98000 miles
What should I do first to make sure all is OK.
I had a 85 vette 4 years ago which I loved. The wife crashed it twice so I sold it. This time she does not get the key. I got her a Jimmy to crash.
I would like to know from you guys is what to look for and what parts I should think about replacing or getting. Man I am the happiest guy I the world.
PS If anyone has a dealer build sheet (has options and price ect) for the 96 LT4 CE, could you Email me a copy .
Ben
Lafayette LA
Sweet . . .
Enjoy ur LT4 . . . a lot of people do exhaust, k&n air lid, cags 1st > 4th shift eliminator.
Since you've had vette's b 4, I sure u know how to care for them.
oil, lube & lots of tlc . . .
By the way - Welcome to :CAC
Later . . . . . .
6 Shooter
You can get YOUR build sheet from the National Corvette Museum I believe. Just give em the vin & $40. or so.
I'd start with all fluids including tran, rear end, clutch & brake.
Congrats on your LT4, they are a wild ride.
I got a chuckle out of your screen name, was it inspired from the two crashes of the 85?
Like froggy47 says, fresh fluids would be a good place to start. I would consider a four wheel alignment if you have any doubts that it could be off.
Overall I’d check for cracked or heat damaged rubber hoses, also pull the black plastic fuel rail covers to inspect there. For piece of mind; on the manifold, the positive crank case ventilation (PCV valve) is a cheap thing to replace.
At the front of the car, I would take a flashlight and check to make sure that debris has not collected in front of your radiator. You should also check from the passenger side as there is cut out in the shroud for a visual inspection.
It’s pretty much the same care as you gave to your 85. Congrats on being reunited with the C4, they are grate cars.
B17Crew
:w
Thanks all
Thanks for all your info. I will use all of it.
I have one more Question (I'am sure there will be more later)
Do the CE LT4 s have a serial numbers ?
Of course, but not a seperate run like the Grand Sports did. They were mixed in with all other 96's :cool
Congrats on the new CE!Your going to love that LT4.Just put the Goodyear F1-ds-d3's on mine...Sticky!Goin' to the track Tuesday the 25th.Hopin' for 12.20's!Welcome back!
