Just need a discontinued bolt!!
  • Thread starter Thread starter gkmr
G
gkmr
Where can I find the lower a/c compressor and bracket bolt?
Discontinued by GM/ Previous owner broke head, so I had to
take a die grinder and cut bolt to get out....
I think it should have a rounded torx head to clear the clutch...
any suggestions...tried several places, no luck...none I can find
in junk yards, etc.
will prob have to go to machine shop and let them make, but
decided to try here...
TIA
Gary
Sorry left it out...87 corvette
left out in request...87 vette
Sorry man, can't help you in your search for a bolt, but I just had to comment on the bolt/bracket issue itself; it seems to be a common problem on those year Vettes I guess. Mine is an '87 as well, and I had a problem with that bolt, and a friend in my local club had a problem with that bracket. :(
Good luck in finding an appropriate fastener.
_ken :w
I had that bolt break on my car also. Couldn't get a replacement bolt either, so I went and found a Grade 8 fastener that fit at an auto parts store. You will probably have to go to several places and might be better going to a place that sells fasteners only. Also, don't use a thick washer under the head and it should fit OK.
I had a problem with a bolt on the manifold. I ordered a few parts from a vette junk yard and they gave me a couple. What I have is a rounded torx head bolt used on the 85 manifold, but I need to verify if I still have it. Maybe we can work a deal, a swap of nickel and dime parts.
