Just Replaced My PS Control Valve...
Green Bay, Wisconsin
1981 Corvette Spectramaster Blue
it seems to pull right a little hard...do you think I need an alignment? Or is it just that my valve is off and needs adjusting...can I adjust it? I guess I did mess with the steering components in a way...need more of a professional opinion
Thanks,
John Dykstra
Assuming it didn't pull to the right before you installed the new control valve, did you follow the valve centering procedure in the Shop Manual? Few valves are properly pre-centered out of the box.
:w John,
Here is a Thread from the past that should help, if not, try the "Search" feature in the blue header above the advertisement, and type in Control Valve ;)
Bud
