Keep Blowing fuse
  • Thread starter Thread starter just me
J
just me
Not sure if this is in the correct forum or not, so here goes. I purchased this ride in Feb 2009 so I do not know what all was done or how it was done, so to get to the issue at hand: I keep blowing the fuse for the power window and the power outside mirror on the passenger side of the vette. little 10 amp I have tried to narrow it down to what I am running but it seems to be random, It can go several days and then all of a sudden I go to drop window and does not work, any one have this issue or has had and can you provide me with insight
Thanks Larry
This is probably more than I know but here goes.
The 10a fuse is probably the
#33 Door Control Module Left, or #30 Door Control Module Right
This controls the window/door locks. My guess is that whoever did the Lambo doors may have damaged a wire and it occasionally shorts out.
Nice catch NJ! I didnt even notice the lambo doors in the pict. I would guess you are correct on this.
JM, being that the car is new to you I would check all the grounds. There are grounds right behind both headlights, some by the door hinges (if i remember right they are behind the kick panel) Search this section for "ground" and you will find many posts with more detail on where the grounds are. Even if they are not the issue its preventative maintenance.
thanks for the heads up on the lambo door found a wire there wrapped it up and all is good thanks for the help
L
