Hello All,
I have a 1975 corvette and the key buzzer never worked. I tested the buzzer with a 12 volt source and it works. Can any one explain how the key warning works? I looked under the dash at the fuse box and the buzzer that is strapped to the wire harness and pugs into the fuse box is missing. I did find a black wire (I think plugs into the buzzer at the fuse box) and when I plug that to the fuse box the key warning buzzer sounds when the key is turned but does not stop until the key is removed. Can you one help? Thanks.
