T
tcarollo
Would someone care to elighten me as to where the two metal tabs on the key warning buzzer (plugs in right below the lock cylinder and behind the turn signal switch) are supposed to connect to? Do the metal tabs connect to the back of the turn signal switch somewhere? Also, does anyone know what the pink wire running to the turn signal switch is supposed to do?
