Front end rebuild.
Hi acman60. That's the way to do it, as long as your in that area change everything and it will last another 20 years. You might want to change the idler arm while your at it. After replacing all those parts if you still have any slack in the steering check the rag joint. Don't let anyone tell you to tighten the adjuster on the steering box. To adjust the steering box takes two adjustments, one adjustment on the worm gear and one on the pitman shaft adjuster. If it comes to that contact GTR1999 he will walk you thru it or send it to him and let him do it correctly.
Last word, as GTR1999 said, check the runout on the rotors.
Enjoy your ride, PG.
