kw readings on the dyno
  • Thread starter Thread starter jim gramms
J
jim gramms
THESE READINGS WHERE TAKEN ON THE DAY
208.9 KW
232.2 KW
249.1 KW
HOW MUCH SHOULD I EXPECT OUT OF A 91 B2K?
Hello Jim,
Converting it to HP you would get:
280.14 HP
311.39 HP
334.05 HP
* I converted to numbers online, so maybe it is not that accurate.
Jim, do you also have the torque numbers? For a B2K they are more important then the HP.
Groeten Peter.
Are these #'s STD or SAE ?
I have attached the dyno results of my 91 B2K. I too had microfueler problems that my shop worked out. Not sure all of the details, but can put you in touch with them. Be careful when it is having problems, it leans WAY out and you could cause serious problems.
Bob
Torque Shop
Dream Giveaway
