Gedmeyer
I put an Edelbrock Performer manifold and Edelbrock QJet carb on and had the catalytic converter cut out of the exhaust. The exhaust system is a true twin system, running two pipes to the rear mufflers, with no equaliser pipe.
All the work was done in stages.
First the exhaust, this mad a difference, I reckon around 5 to 10 neddies extra and the sound was deeper, but not too barkier, if you know what I mean.
Second was the carb and inlet manifold. This made the most amount of difference. The engine just came alive!
I am enclined to agree with Moe Jr about the changes he has made. I haven't changed the gears in the diff though, they are still 2.87's. She won't break traction off the mark, just grips in with those new Falken Tyres and put's you back in your seat.
That's the way the boys at GM designed it anyway. I was watching a video on the 81 the other day and they mentioned it on there. I would like to change the gears to fry a little rubber now and then, it would be good to see those Falkens burn white smoke, but think that my freeway driving might be affected. We have a 110 KM/H speed limit on our freeway here in some parts (that's around 68 MPH) and she sits on around 2500 rpm now.
Good luck with your rebuild.
Cheers
Tony
