Ill second that CRANE 114132 suggestion, its proven to be a good 30-35 hp increase with zero problems, in many vettes over many years..its about IDEAL for a nearly stock TPI, engines power curve, BTW it LIKEs being matched with 1.6:1 ratio roller rockers, and DESPITE what it says in the instructions it doesn,t REQUIRE that 3.73:1 rear gear ratio, or higher fuel pressure BUT IT DOES work better WITH THEM INSTALLED, as it allows the cam to produce to its full potential
http://www.cranecams.com/?show=brows...32&lvl=2&prt=5
The 114132 is a flat tappet cam. But I'm sure Crane Cams can recommend a similar grind for a roller block. I would call their toll free tech line and ask. I have the 114132 in my '86 and think it's great.
