Re: 500hp for $1,500....
Vette/Berlina-coupe said:
[Bd.) install $300-(Summit-800/230-3030)/Fluidamper viscous-hub for greater power/smoothness; e.) don't stroke the engine to 383cid, it results in a less-efficient engine because of excessive-angle at which conrods are placed at when crank-throw is half-way up (and thus trying to shove the piston scuffing into the cyl.wall), --thus more heat, less fuel-mileage; f.) have a skilled/machine-shop do a 7to9-angle valve-grinding job, -resulting in more aerodynamic air-flow between valve-head and valve-seat, --hence, greater volumetric-efficiency (more air gets sucked-in); g.) high-volume oil-pump; j.)$99, 6:1 Summit's/roller-rockers (less-friction/less-heat); l.) so-called zero-clearance/self-sealing/no-leak Piston-rings[/B]
After 40 years of building small-block Chevys, I'll offer the following:
1. A Fluidamper doesn't gain any power, waste of $300 for a street engine; SFI-rated balancers are only required in certain modified race classes due to suspect durability of the OEM balancer at sustained extreme rpm.
2. 383's are built for torque (where the fun is on the street), not efficiency; you'd need NASA-level instrumentation to find any additional heat. There are tens of thousands of 383's out there, and they run just fine.
3. Any decent shop with a Serdi machine can do a good 3-angle valve job; anything more than that is wasted on a street engine, and you'd never see the difference. You'll gain much more with minor cleanup of the bowl area behind the valves and port-matching the intake to the heads.
4. No need whatsoever for a high-volume oil pump - the SB Chevy has an outstanding oiling system with the stock pump; oil pressure is a function of downstream restriction (bearing clearances, lifters, etc.) to flow, not volume; the additional oil just unseats the bypass valve in the pump and dumps back into the sump.
5. Roller or roller-tip rockers reduce friction and valve guide wear, but going to 1.6:1 isn't worth the hassle of enlarging the pushrod holes in the heads, checking/replacing springs to avoid coil bind, etc. - any power increase from the change to 1.6:1 is insignificant in a street engine.
6. "Gapless" or "step-seal" rings are expensive, time-consuming to file-and-fit individually, and you'll never see the difference in a street engine. A good set of moly-faced conventional rings (Speed-Pro, etc.) will do the job just as well for far less cost and hassle.
