L48 w/ vortec heads
  • Thread starter Thread starter Scooter76
S
Scooter76
I have decided to build up my L48 a little bit. I would like to hear any opinions as to how it may run. Heres what I am going to do:
Vortec heads upgraded to handle .520 lift.
Performer vortec intake, keep the origional Q-jet.
Comp extreme energy 262/270 cam. (218/224, .493/.500 (1.6) 110 LCA.
1.6 roller rockers
TCI converter 2000 stall
Headman headers, dual exhaust, no cat.
I'm hoping for 325 or so hp. while still being a mild combo.
I thought about going the crate motor route, but the budget is keeping me from it.
Thanks in advance
I went a similar route with my '82 (see sig.). You will like the hp/torque and 325 should not be a problem. CHP built a similar engine with a stock GMPP bottom end a nd the XE268 cam and they put out over 400 hp/torque at the flywheel.
Good luck
Here's that GMPP 350 build
Here's a link to that GMPP article -
I've been researching a modest cost
build for mine, had about set on this
setup although hoping to score a
hydr roller reasonable. This story has
about got me convinced to do a
Comp Cams 262 (they recommend it over the 268 they used, saying it would do more torque in driving rpms without noticeable horsepower difference).
I was amazed at their final results with upgraded Vortecs.
http://www.corvettefaq.com/c3/goodwrench/GM Goodwrench 350 test part 1.htm
Also, just FYI, right now there are upgraded Vortecs on ebay that are good for like .550"lift instead of the .510" like most of them - also have the larger valves, just a slight tad more than the other upgrade versions.
I'll find out the vendor and post here.
In the meantime, here's a bunch of righteous buildups with non-exotic parts.
http://ryanscarpage.50megs.com/combos2.html
http://www.geocities.com/MotorCity/7610/dyno.htm
