brumbach
I'm building (or having built) a correct L79 for my 65 vette. I've got the block, heads and intake manifold. Now for the internals. I've located a crankshaft with the following description. Will it work? What difficulties may I encounter if I use it?
"It has been index ground on the rods only. This is a process where the journals are all ground exactly 90 degrees from each other when blue printing an engine. It has sat around a significant time since grinding and will need to be ground on the mains for sure and maybe a regrind on the rods also. It is currently standard on the mains and .020 on the rods. It is part number 4577."
What's your thought on this one? " #2680 forged crank small journal, It mic's at 2.300 mains and 2.000 rods."
Thanks,
Bill
Thanks,
Bill
