Vader,
I noticed on your pics that you also removed the heads. Was that intentional? The pistons look ok. Were the cylinder walls ok? How was your #8 cylinder? I am curious, for I found some water signs on the #8 cylinder (Actually my mechanic did and informed me). He says that the #8 is common for having signs of water if a vehicle is used during short drives and long rest periods. Condensation settles on acount of valves being open at the #8 when turned-off...not sure about this.
Well...maybe some of our L81'ers would find it usefull to enhance the L81. A 1.6 rocker ratio with some good stamped rockers from CompCam or Crane would yield close to 0.026" more lift. A 1.7 ratio would yield approximately 0.052" additional lift. The short duration helps keep whatever compression is there (8.2???). The bigest advantage would be from the more accurate lift multiplication thorughout the rpm band.
Will it help make 14-second et's by itself? NO, but it would help along the L81's in stock configuration. Remember that plenty of our members prefer their Corvette as close to stock as possible. Some components or systems may have been upgraded or improved since the 1980's, and if the parts are in need of replacement, then a replacement part could bring added reliability. Case in point the stamped-steel rockers.
What did I win anyways???....(I cheated...I looked it up in the shop manual)...:L
I'm afraind that even 1.7:1 FMS rockers wouldn't help that thing.
