W
WolfeBros
I am getting some lifter noise on my low mileage (4,400) coupe.
Noise appears about 30 seconds after a cold start and will sound until the engine reaches normal temperature. At that point it seems to diminish. If I shut the engine down and let it cool down just a bit....the noise comes back again. It sounds to me like just one lifter in the right bank. It is a fairly solid tapping noise that can be heard fairly easily inside the car. It also varies with engine rpm. Just had an oil change (Mobil 1 ) and was hoping that maybe this would help but it did not. Any ideas, suggestions? Is this common? Car is still under warranty. I just bought it two weeks ago so I don't know if it always made this noise. Thanks.
