Was mucking around with the cooling system yesterday, installing a lower-temp fan switch. Refilled the radiator and overflow bottle (filling to top of neck with engine warm). Went for a drive. Temp gauge never goes off "LO". Oil temp climbs normally, but not coolant temp. I checked after the engine had cooled off and the level is still to the filler neck so I don't think there's an air bubble. I guess the thermostat could have suddenly decided to stick open. I know how to check the thermostat for proper operation, but how does one test the temp sender? And am I correct in thinking it's the wire just below the overflow hose on the filler neck? Are there multiple senders? I'm worried about driving it - if the coolant isn't actually flowing for some reason, will it overheat the engine without my knowing it?
I guess there's always the chance I replaced the wrong sensor, though I kinda doubt that. I took out the one between the last two cylinders on the passenger side, which is where both the Haynes and the new switch's directions said it would be... The fan doesn't run at all, which is to be expected if the temp is low.
Thanks...
[RICHR]
Thanks...
[RICHR]
