M
		Moonunit 451
http://forus.com/moonunit/Corvette/DOA VETTEb.jpg
So, my motor went away, 114,000, bummer days. I've been working on parts to rebuild for a little bit. Got some ported polished cast heads, cast rods and the 219 cam is en-route. I've got a line on a good SR I'm trying to work out a price on. Planning forged pistons, rings, lifters, gasket kit, water pump, oil pump, and on and on it goes, deck the block and some other minor machine work. I'm in about $ 850, and figure $900 + for the SR then add all the other stuff. I'm figuring probly around $3500 or so to do it right.
So, what do I see today, but, "fresh 400 block, rods, new cast pistons, fresh crank, full set of clevite 77 bearings, oil pan, cam cover, valve covers, a set of cast iron heads done by Zimmerman's racing in Greensburg IN, a new water pump, a new balancer and flexplate. New rings, stock lifters, cam, gaskets. New oil pump, new fuel pump, and a Comp Cams 501/501 cam kit witch has a new cam, lifters, double roller timing chain, keepers, retainers, and springs. The rotating assembly has been balanced". $1350!
Under $300 to get it to me, then build it, do an exchange instead of having to have my engine out for a month to build it, then try to remember how everything goes back together. All the stuff but the intake is there, no real extra expense (splay the main, but I was going to do that anyway), and sell what I don't use, get a fair ammount of my money back.
I'll have a 400 + hp engine vs. 300+. I've talked to the guy and it's mine if I want. I believe him to be haonest and am comfortable finding a way to do the deal that will protect each of us on the financial side. I suppose there is always a chance that there may be defective parts or something, but my gut says the guy is straight up.
I'm looking for advice and comments - Quick. Thanks everyone!
ad
