Looking for Interior windshield trim, 80.
Dood1
here
The plastic piece that covers the top of the windshield frame on the inside of the car is cracked, and I can't find anyplace that sells it. The only parts I can find are the plastic covers that run up the sides of the frame, but not the top piece. Any ideas where to look?
If I'm not mistaken, you're looking for the Windshield Header Moulding. I've seen it both on the Zip and TLD site, but without a picture, so I'm not sure. Anyway, try either of these two sites, but you'll probably need to give them a call to be sure before you order.
Zip Corvette http://www.zip-corvette.com
The Last Detail http://www.tld-corvette.com
Good luck,
Steve :w
I recently got one from Last Detail. They had it drop shipped from Corvette America. So either one should work.
Thanks guys, went to corvetteamerica.com and they had a picture of the header molding, that's exactly what I need. 50 bucks for a piece of plastic :r but what can you do, it's a corvette ;shrug
Just a heads up. When I installed mine I had to enlarge some of the holes to get them to align properly. Check that out before you tighten any screws.
Good suggestion, mine was cracked around a screw hole.
