Help! Looking for trans lines
Marv02
California City Ca
1986 C-4 Corvette
I been looking for New pre-bent automatic tranmission fluid cooling hard lines pressure and return from trans to Rad.
I have looked all the normal places so far no luck anyone out there know where I get a set.
1986 Vett/700R4
I made lines for my Vette-under-truck project. Not rocket science, but definitely a learning curve. If you have the old lines to model, lots of time could be saved over the bent coat hanger approach. The Chinese tubing benders work but it's a question, at times, of whether the tube or the bender will bend permanently. The 'real' benders are constructed, also to make the job easier, as good tools will.
I have all the tubing bending rack at work but I did not want to bend take home see if it fit then bring it back to work redo it over and over.
If I could find a set per bent.
Yes it cost more to buy a set done already but once again I just have to bolt them in and I done.
