Peer81 said:Looks like they had a good day down @ Jeal and Sones!
Malc: Could you give some more info on the runs?
Groeten Peter.
detonation issues........what's meant by that??callaway4fun said:Here is a link it says he put down 350 hp but had detonation issues. http://www.corvettecentral.co.uk/visit_to_geoff_jeals.htm
Thanks Josh, that does help. I had read about guys having trouble with detonation before and had no clue what that meant. Thanks again.SurfnSun said:Detonation is when the gas prematurely ignites in the cylinder. So while the piston is coming up the exploding gas is trying to push it back down. It is a certain killer on forced induction cars. The compression in the cylinder heats the gas up to a point that it ignites. Its usually caused by poor gas or an excessively lean A:F which makes the motor run hotter. Hope that helps.
