Looks like . . .
Missoura Ozarks
2012 💯 4LT GS Roadster
. . . my water pump starting to go ! :cry I'm seeing traces of coolant thrown-up by my pulleys and belt on misc. stuff.
Can't believe @ 26K the critter's going to give up the ghost ! :r
Rowdy1
Lake Hopatcong, NJ
1962 CORVETTE-SOLD 2004 Z16 Z06 CE
Other Places
I'd pressure test it first. Hose clamps, all that stuff before I put a new pump in it.
Missoura Ozarks
I'm taking her in tomorrow for a check-up . . . hopefully it'll be a hose. Have to say by my visual running check this evening, it looks like a pump or pump seals.
vettl83
Casper Wyoming USA
91 L98 Quasar Blue, 91 ZR1 Red, 07 AO Coupe
Hard to believe it's the pump with so few miles. My 84 had a very slight leak out of the weep hole at 76,000 miles. Anyway maybe you'll luck out and it will just be a hose connection or something simple. Good luck 91 ZR-1 #2039
96Holly
Livonia, Mi, USA
96 LT4 Polo Green Coupe
Been there and doing that....
I am in the process of change my pump. I think that mine started to leak around 30-35 K. The dealership said $700 to fix and replace the pump..... ya ok...
unfortionatly my leak drowned my distributor. So with the distributor is being chagned as well.... Crazy things....
BigRed
Edmonton
1985 Bright Red Rocket
(Hint)
I do that all the time, sometimes I get mind block and type something totally different that what Im thinking not to mention spelling..
At the righthand bottom of the post just click Edit that will allow you to change what your trying to say..
Missoura Ozarks
Pressure test revealed it was the water pump . . .
Have a friend who owns the Local Pontiac Dealership, $406, installed a New AC Delco Water Pump with a Coolant Flush !
:cool
Back on da Road again, I just can't wait to get back on . . . .
