M
Mhelvic
Wife's 98 vert with tire sensors keeps losing air. Sometimes she will drive to work and return home with no problems, however at other times when she drives to work and leaves at the end of her shift the tire will be flat.
It's used primarily as a weekend (no kids) driver and we've driven it all weekend with no problems only to find the tire flat several days later.
I took it in for service and they could not find a problem, when it repeated itself I took it back and they found a small amount of air escaping from the screw on the tire stem. They changed the screws and I thought problem had been fixed, but it began occurring again, I checked all the stems and the screws are still tight.
Initially it was only the left rear tire experiencing this problem, but after having it checked out now both rear tires are having this problem.
Has anyone else experienced this problem, if so how did you fix it?
