C
CAJUN C4
87' Engine
It started about 6 mos ago losing about 2 quarts of coolant a week.Put it on the rack and the very last head bolts on both sides show signs of leaking coolant. Maybe I didn't put enough sealer on the threads? I believe these bolts go directly into the water jacket.You think I can fix this problem by taking the bolts out and add sealant to the threads or is it possible it's a head gasket issue.It doesn't leak enough to show visibal signs on the ground. It must evaporate being right at the exhaust manifolds.
Anyone have or hear of this problem? It did however,not leak a drop for three years after the re-build.
Perplexed
Perplexed
