Lots of fun- here's a riddle...
KANE
Moderator
KY
Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
So here is a riddle-
What would cause the back up/turn signal fuse to blow each and every time the car is started and moved from park into drive????
(Hint- the contacts are not insulated and it sits under the console)
FYI- I just spent the last hour trying to figure this out and pouring over diagrams. I did finally get it- but it took a while. It wasn't caused by what I thought would do it at first. Then it hit me- DUH....
Answer...
It was the neutral safety switch!!!
I had a something grounding out across the contacts that are exposed.
:crazy
