Corvette Emma
Once in a while while driving, the low coolant message pops up but the coolant level is actually fine.
Has anybody else encountered this problem?
tyrel said:Emma, with your car cold, check the fluid level of your coolant reservoir to make sure it's within spec. There should still be coolant in there, since the system draws in coolant while the car is off and cooling and lets it out again when it's hot and running.
Then, with your car cold (never remove the cap when the car is hot), remove your radiator cap and start your car, and let the car come to normal operating temperature while observing the coolant level in the radiator. It's pretty easy to see if the coolant level actually falls below the level of the sensor.
If the coolant level doesn't change in your reservoir, you may have a leak somewhere, check your garage floor. Sometimes the car can develop tiny coolant leaks that quickly evaporate, these are hard to find. It might also be the heater core, the one on my 89 just started leaking one day, there was a strong smell of coolant inside the car and there was coolant dripping onto the passenger side carpet. You might also check your oil, if there is a head gasket leak the oil may look lighter than the dark chocolate color it's supposed to be.
