You will want to be very careful with the ultimate adjustment of the rear spring heights.
Too high or too low and you mess with the weight transfer characteristics of the car, and effect is likely to be seen under acceleration and/or braking.
Worse yet, side to side disparity will result in uneven cross weight (contrast of total L/R + R/F vs R/R + L/F weights). This will (i) produce inconsistent response in cornering, one direction compared to the other, and, (ii) unpredictable transition from one to the other.
Process I would recommend would be to (i) set the car up on scales, (ii) start from the front to rear ride height differential recommended in the service manual, and (iii) adjust to 50% cross-weight with average fuel and passenger load.
To the extent possible, try to make adjustments by raising one side and lowering the other in equal amounts, instead of trying to take all adjustment from one side.
Alignment should be set first. Be certain that tires are cold and at their proper cold pressure before making any adjustments as well. These are both significant!
If cross weight is not properly adjusted, the car literally rocks back and forth on the diagonal that is more highly weighted.
Given all of this, you could have an otherwise perfect alignment, etc., and have the car still handle poorly.
Hope this helps.
