LS1 is running
patsnitrovette
absecon,newjersey
1973 electronblue LS1
Well she finally runs,still have some more things to finish up,p/s pump and tensioner,hook up my coild air tube and then ill be ready to take it for a spin,but she fired right up no hesitation.It really sounds good with the hooker sidepipes i wasnt sure how she would sound but i like it.Feels different then the tpi motor i had,but the tpi was real torquey.
http://home.comcast.net/~pats73vette/LS1.MPG
Are you using a stock tach?How did you hook it up?Ive been thinking about LS1 swaps lately but i want to keep the all the stock gauges.
i have 5 inch autometer tach and speedo in the car,i had them change the tach output in the pcm to work with the autometers.
i used my hooker sidepipes,and cut off the flanges and bought ls1 header flanges from the gm dealer and welded them on,it wasnt easy but i got it to work,2 of the pipes line up and 2 dont so i had to move 2 of them over then reweld them up.But now i have sidepipes on a ls1.
my custom air filter setup i made,gone to seal it to the hood and use the cowl induction for air.
Well i took it outside yesterday just out front and it idles way to smooth for me,gone to be doing a bigger cam swap .I guess i was so used to the zz4 cam in the tuned port motor and they torquey feeling of the tpi these ls1's feel way different.
http://temp.corvetteforum.net/c3/patsvette/ls1sig.jpg
