Stan's Customs
Just happened on a good original 370 hp solid lifter LT1 350 ci engine. ..
Curious what changes most would make to this engine for todays fuel, regarding cam, heads, compression etc.
I believe milling the piston domes to about 10.0/10.5 compression ratio and installing hard valve seats would be the minimun...Maybe the cam would still be all right, I'm not sure at that compression. Not sure about how the heads stack up against todays heads either...
The engine is not cheap (but fairly reasonable)...so I'm thinking the money might be better spent on a later engine...like the crate ZZ4
...or would just about any good 350, with Dart heads or similar, a hydraulic cam, be about as good...or better?
It's been a long time since I had one of these engines and I really liked my big blocks better. So I can't say that I remember the LT1 performance well enough to compare them to todays combinations...any thoughts... what's best smallblock route between the two for a comparable engine.....
