69MyWay
This conversion has been around for a while now. However, I have yet to run across an article that really put it to the test.
The Sept. issue of Popular Hot Rodding has a 1988 Camaro that gets the conversion. What is interesting, is this very same Camaro had a Accell Super Ram on top of a bored and stroked 350 with a hefty cam, head work, and only 9.3:1 compression.
They had spent countless hours on the dyno with the Super Ram and had maxed out the performance of the car.
They then dynoed the Super Ram, and ran the 1/4 mile. Then they ripped it off the engine.
They took a stock LT1 intake, and did the mod to the rear to accept a small bodied distributor (as used on the late 3rd gen F body), and drilled and tapped the rear ports for water jackets. They ran those water jackets into a universal radiator thermostat free standing housing. That then plumbed right into the radiator.
They made a minor trim to a accessory bracket to clear the throttle body.
They buttoned it back up, and hit the dyno.
Peak HP climbed between 500 and 1,000 RPM higher than the Super Ram, and made just a tad more. Peak torque dropped, but stayed constant LONGER over a more broad band. They felt if they had more dyno time, they could have done much better, but were limited.
In the 1/4 mile, they were mear 1/10's of a second different in the 1/4. The Super Ram had a faster 60 foot, and 1/8th, but the LT1 intake caught up, and was making more time at the end of the track.
All and all, his conversion was around $300---for the cost of the manifold, gaskets, waterneck bypass, and misc parts.
Had they compared it to a L98 manifold...it would have been a slaughter.
So...I have to look the article back up and get you guys the links to the Fbody based sites that go into more detail on the conversion.
