personally i think this kit is over priced and over hyped. all stock LT1's i've seen dyno on a dynojet has been in the 270-280 rwhp range for 60 hp i'd be super PO'ed!
the only way that cam will pull 425 hp at the crank is with FULL bolt on's and your still only pulling roughly 352 rwhp.
with a compentent tuner using LT1 edit you can get around 20 rwhp and with headers your looking at another 20+ rwhp now your at 40+ rwhp. so your telling me cam, heads, and 1.6 rr's only gave you about 40 rwhp? something is fishy here.
if i had an LT1 this is what i would do... aftermarket heads cnc'd, 230/230+ duration at .525+ lift on 1.5 roller rockers with your LT1 intake portmatched and a good dyno tune using LT1 edit. that alone would put you well over 425 at the crank and most likely over 380 rwhp.
for 60 rwhp i'd throw the jug on it and save 1500 bucks
hope i didn't hurt anyones feelings but GM technicians are NOT tuners and more than likely don't even have LT1 edit! all dealership mechanics are is part changers and thats the bottom line.
1 good thing about LTx motors is the more milage you put on them the more HP they make. popular hotrodding did an article on a 93 Z/28 and road tested it for 60k miles and it pulled more HP at 60k miles than it did at 3k miles.
if anyone wants to know more about cam selection call my friend Joe Overton. he knows alittle about LT1's since he has the fastest NA LT1 in the world! not even the fastest NA big cube LS1 can keep up with a lil ole 388 LT1
http://www.lethalefi.com/
