Peabs
Have a 96 w/LT4 and it has low to no oil pressure at idle and only about 10-15 at 3k rpm's. Also, at start up the pressure takes about 2 to 3 seconds to build up. Oil level is OK, clean and with Mobil 1 5W-30. No valve chatter or other unusal noise, but when I 1st noticed the issue the engine started to overheat. Needless to say it is parked in the garage. Bad oil pump? blocked screen? Bad filter? Other?;help
