I think overall the LS1 is apples and oranges when compared to a LT4. The LS1 is, as others have mentioned, refined. The C5 chassi is light-years ahead of the LT4 as far as stiffness. You take off the targa top on a C5 and you’re probably not going to sacrifice body stiffness as much as you do in a C4.
The C5 is much roomier and holds more cargo. With the C5, you have runflats to get you safely to a garage should you have tire problems (Extended Mobility Tires were optional on ’94-96 Corvettes). No antenna worries on a C5 as the antenna is in the glass (at least on coupes).
From what I’ve read, C5s have their share of issues. Column lock, battery leaks destroying vital wiring that is directly below, oil consumption, etc. LT4’s have their issues as well, Your standard share of LT series weak points. Intake manifold leaks, weather stripping (one of my favorite personal GM gripes), water pump leaks, delaminating of transparent targa tops, etc.
I test drove several C5’s when I was in the mood to upgrade. After driving 97’s, 98’s, 99’s, and finally 2000’s, I thought why bother? My LT4 feels just as strong when it comes to engine pull, actually you “feel” the engine more in an LT4 than in a C5. I chose not to upgrade because their was little difference as far as acceleration. My LT4 runs 13.2 @ 107 without batting an eye. A late C5 LS1 would more than likely be quicker after the 1/4 mile, but up until then, the LT4 is competitive with the C5 in my humble opinion. If you want a powerful, compliant sports car, the C5 is unbeatable, unless you get a C6 of course.
They really are two completely different animals, you need to get seat time in both and see which one feels right. When I was C5 shopping, I called on insurance, the C5 was cheaper to insure than my LT4 -- so that is another thing to take into consideration.
It’s more than LS1 vs. LT4 when talking about these cars, the entire architecture is different. Design on the C4 started in the late 70’s, I think. Design on the C5 was started probably in the late 80’s and developed throughout the early 90’s.
In the end, you can’t go wrong, they’re both Corvettes!
B17Crew
