W
WhiteKnight
I have about 9 of the nuts that are bad and of course 9-10 studs that also need to be replaced. The front has 5 between the two hubs and I'm not sweating replacment on those.
All 5 of the left rear were so cross threaded I had to use a air lug wrench to remove the nuts.
My question is do I need to pull the spindle to replace them?
I'm replacing the parking brake hardware and it looks like there will be room, just woried about messing up the spindle and bearing.
Thanks.
Thanks.
