garylt
How do you decreened the MAF. garylt.
Agent 86 said:Direct your energy elsewhere. Waste of time in my mind:W
MBDiagMan said:I remember now how to remove them. You take a knife and put between the edge of the screen rim and the outside of the MAF and then roll the MAF around to wedge the screen off.
Good luck,
Louis Bartay said:Does the 96 LT4 have the same MAF?
Vettefan87 said:I believe yours already has them removed from the factory, but I could be wrong, that might be an LS1 MAF, just take yours off and look at it and you will notice the screens.
MBDiagMan said:If you expect to see any change on a dyno from this modification alone, you better not be using an old style dyno with analog gauges. You will need to be using a modern computer monitored dyno that will give you decimal points.
Even then the minor variations from run to run will probably be greater than the measurable difference from this mod.
Good luck,
