Ken
Gone but not forgotten
The television show Rides! had an espisode featuring Rod Millen and his work with Toyota, as well as the military. One of the things they talked about was his work on the MagnetoRheological Fluid Optimized Active Damper Suspension for the Hummer. The neat thing was the demonstration of how the fluid worked.
They holding a piece that represented the shock rod in a pan of the stuff, and when they energized the rod you could see the stuff harden immediately to rock solid. They also showed how you could release it a little at a time or all at once.
I had a mental image of how the shocks worked, but this was actually a pretty cool demonstration which gave you a very clear picture of what was happening. :cool
