E
ElectroCulture
A while ago I posted about an error and problem I have been having with my 97 C5. I get the error message "Service Traction Control System - reducing engine power" and then I can't get anymore than 1500 rpm out of the car.
I took it into my local mechanic back in December and they pulled the codes ... told me it was a matter of having a bad battery and it was causing problems with the electrical system ... so I had them replace the battery. Got the car back and 30 miles later the problem continued ...same error message and result. I took the car back and they did more investigation ... they told me the TAC module needed to be replaced, so I had them replace it. Got the car back early Jan, drove it about 30 miles again and the problem re-occurred.
The mechanic has the car towed back ... they looked it over for a week and then sent it to my local Chevy dealer. They did a diagnostic and dug around in the electrical system and then after a week proceeded to tell me it had a loose wire and the TAC module was programmed incorrectly. They gave me the car back and lo and behold ... the error occurred again about 30 miles later again.
Had the car towed back to Chevy ... they dug around some more for another week or so ... told me the APP had failed and needed to be replaced. I asked them "Are you sure this is it?" ... "Yes" they told me. So ... I had them replace it. And yes, you guessed it when I got it back, 50 miles later same error occurs. They towed it back to their garage and now have had it for the week again, with no results yet.
Needless to say, I am beyond frazzled ... thoughts or suggestions please? I am at my wits end ....
~Craig
~Craig
