Master cylinder reservoir
  • Thread starter Thread starter Ryan
R
Ryan
Hi guy's
Last update!! I,ve just finished painting my donor birdcage and its like new. And I've also cut the door jambs to allow the old birdcage rollbar to come out. What a nightmare that was to get it out.
My question is ... is there any replacement or lets say custom mastercylinder and powerbooster combo with the plastic reservoir like the C4 for a C3 corvette? I dont like the original one.
Also where can I find it and how much will this cost? Will it fit the originalsteel hoses that comes from the proportioning valve?
Thanks,
Ryan
The master cylinder and reservoir are a single casting. You'd have to replace the whole unit, and the C3 master cylinder is signficantly superior to the C4 unit.
Actually, the ZR1 used a very similar master cylinder to the C3. I'm not sure if it looks different, but I believe is had a similar internal bore, so maybe it could be somehow mounted to your car, but it would probably be a difficult and expensive proposition.
Joe
