Marlar
JohnZ said:A.I.M. = Assembly Instruction Manual - all the vendors have them. You'll also use the previously-unused lower hole in the pedal for the pushrod to the booster, and they should have included a bracket that bolts to the now-unused upper hole in the pedal that will operate the brake light switch.
Thanks. Vendor tells me the bracket referenced by birdball is for the bottom bolts and is not needed for this application. I also am told that a pair of existing studs need to be removed and replaced by supplied bolts. Just whack them out with a hammer? Hmmm, hammer and fiberglas firewall don't seem to be a good mix.
:confused
otfl
