I'm more impressed than ever with the Vette Brakes Performance Plus suspension kit.
I finally got around to adjusting the spring rate (front and rear) today, and the ride is like the difference between night and day.
When I first ran some neighbourhood tests at the highest setting - outboard position #4 (many, moons ago) it felt like riding a ride-um lawn mower down a cobblestone street. I backed it off to position #3 and have used that setting until today. That was a reasonably good ride improvement, but man-hole covers still felt like a 2-foot deep pothole.
So now, at position #2, it still handles amazingly well, but it's also livable.
What is truly amazing is how easy it is to adjust this suspension -- front and rear. Change the spring rate? Okay -- just move two bolts front and two bolts rear to different holes and you're done. Fifteen minutes after getting the car up on stands and the job is finished.
Change the ride height? Sure. Just adjust two nuts front and two nuts rear up or down and you're done........except in this case, you'll need to check the alignment.
I'm very, very happy with the design. Thanks VB&P.
