MC solenoid
equineman
Marysville,In
1981 Black coupe
Got new digital dwell meter. Can't seem to get any reading on either the green or the tan/blk wires. Anyone know what wire coming out of the ecm is the MC solenoid dwell wire? Thanks
There should be a single green connector in front or the carb (right side). That should be the dwell connector as far as I know :)
Groeten Peter
I never used a digital dwell meter, but the pink/black wire is 12v from the gauges fuse, the blu wire is the signal side. Connect the meter to the blu wire and any switched 12v line or across the solenoid and you should get your reading
